TD_airbrush_works, here's what you do to check and see if your fuel pump relay is the proble:
The fuel pump relay has four wires going into it they're orange, grey, green, and black. The relay is the closest one to the driver side fender on the fire wall. To see if the relay is the cuase of the slow start you should have at least a test light. Pull the relay out of it's base, now you can accsess the terminals of the wires going to the relay. You need to see if you have power at the orange wire, it should always be hot. If you have power there, take a jumper wire and jump power from the orange wire to the grey wire, doing that should make your pump run. Now go to start it and see if it doesn't fire up quicker now that the fuel pump is running. If the fuel pump doesn't run after you jump it you have issues with wiring back to the pump or the pump itself. Also check and see that the green wire has power for a few seconds after you turn the key on if it doesn't you got problems there. I don't have a wiring diagram in front of me but the black wire should be the ground so if you have anything like a DVOM that you can check continuity with check the black wire's terminal to make shure it is grounded.
If this doesn't help do a search on the subject, type fuel pump relay and you'll see what other people have wrote on the subject but hopefully I helped you with this.
Also, I don't think the 17"-18" combo works because you need to have the same diameter tire front and rear, you might be able to make it work but it would look like shit with a higher profile tire in the front to match the diameter of the lower profile tire on the rear 18"s.
