Re: Half shafts
Dave P.
I have also had the transfer case out. The viscous coupler looked to be normal (no discoloration). The chain was tight and the fluid was in good condition. The truck still makes the popping loise when I make sharp turns, but when turning if I hold the brake and add power there is no noise. I had a friend drive in a tight circle while I looked under the front end. I could not see anything binding or what could be making the noise. It "feels" like the popping is coming from the front end and not the transfer case.
Thanks, Jeff.
