typhoon12
Tyhoon12 #0489
I was going to give my truck a quick “fluid flush” and a friend of a friend is the manager at a local Jiffy Lube ??:tup:??:tdown:?? and recommended the following...
Oil change (Synthetic)
Oil filter
Remove old coolant and replace with new (what is the correct color?)
Remove old differential fluid and replace with new
Remove old transfer case fluid and replace with new
Fuel system cleaning (I already replaced the fuel pump and filter)
Remove old transmission fluid and replace with new
Remove old transmission filter and replace with new
Any recommendations on fluids and services mentioned above?
Thanks,
Jason
Oil filter
Thanks,
Jason
