Electronic Spark Control?
Pittman
I figured as much.
Every time mine throws a code at me I just push and jigle the connector and it goes away. It happens ever so often. Ive damn near been mad enough to solder that bastard on there.
Cool having a tech online.
1BADSUV
Thank's
Thank's
Thank's for all the help. I removed the coil to have access to the knock-sensor and could tell that the blue wire is wrapped around some cabling and I pushed it down so it was not as tight and everything is perfect, no code 42,43. Why did the factory wrap that one blue wire around the largest bundle of cabling? You can tell if the motor is torqued enough that it could pull the wire off of the knock sensor.
Cheer's
