well did it the hard way. took out lower shock bolt and took out the tie rod...had to man handle it to get it moved...still not enough slack...it hit the center link end..moved the steering over to the right. almost but still not enough l... then i released the caster nut to the i guess upper ball joint... bingo got it out easy after that.
problem is before that tring to force it in.. the plate on the flange side came out and would not stay in...after getting bolts lined up i like a tire went in cross section hoping it would seat it self after tightening... who votes that its gonna leak grease later????
now the real problem...when i went to push the rotor and whatever its called assembly up to get the upper ball joint caster nut back in...it just wouldn't go...jacked it up and hit it slightly ...still would not drop in place...
what should i do now...i guess replace the upper and lower joints...I was really looking for detailed info on this earlier...I should've told ya'll I had never done this before. on any car truck... what should i do ??? thanks for the input
