AWD went bye bye
Ghostsyclone
i had my front diff rebuilt and i went for a drive after and my rear wheels just spun like crazy when i would try to take off. with boos or without i soin. anyone know whats up with this. i need help big time. everything looks right and is all hooked up but there is no movement on the front wheels.
syclone0577
Re: AWD went bye bye
What exactly is this?
Sy Guy 0024
Check your front pass side axle to make sure it hasn't popped loose from the front diff. If you can push it in an inch or so and feel it "click", then there is your prob. I had the same prob a while back, for whatever reason the axle would disengage from the diff while driving, leaving the truck in 2wd. Tried new axle retainer clips, rebuilt the front diff, still no luck. Had to get a new diff to fix the problem.
'JustDreamin'
Dream: 6LV8 Turbo Bravada
Check Carparts.com.....Search the salvage yards near you (or far, if you're willing to pay shipping). Midwest seems to have the best prices.
You're looking for the front axle assembly for a S10 pickup or Blazer. You do not want the ZR2 package. Starting in like 97 or so (I'm not sure when) GM put a drain plug in the case for the front diff, which is kinda nice. If you've got the stock gears in your truck, you need to find a 3.42 geared axle.
You can buy parts and pieces for these diffs, but from what I gather, they're tough to rebuild and get right. And for the cost of a set of gears ($150 or so) you can get a complete axle, fully assembled.
BUT, first you should really figure out whether its the front diff that is messed up or the transfer case. If the Viscous Coupling in the TCase went, replacing a fully functional front diff WON'T fix your problem.
A good used Tcase would also be your best bet if that's indeed what went south. Search for '91 to '94 Bravadas, they use the same basic case. There are some differences in output shaft configuration, make sure to get a case that will bolt up.
'JustDreamin'
KFC_Or_Bust
A lot of bad things happen, like the front tires will be spinning at a different rate of speed than the rear tires. Last time I checked that's generally a horrible thing to do to a vehicle.
'JustDreamin'
Ghostsyclone said:
what happens if you put something other than 3.42 geared axle in the front diff?
The front and rear axle ratios need to match, or several things (all bad) may happen.
1.) Tcase may grenade (or otherwise die a horrible death).
2.) Truck may be completely undriveable (unstable due to tires sliding / slipping / spinning).
3.) You may break something else in the driveline other than the tcase.
Reason I said 3.42's, is because that's what these trucks came with from the factory. If you know for a fact that your truck doesn't have the factory gear ratios (and if there is any doubt, check it), then you need to make sure it matches whatever is in the truck.
Or, you could use this opportunity to swap gear ratios. 3.08's, 3.42's, 3.73's, & 4.11's are all readily available ratios, but you've got to swap both ends (front and rear) which gets a little pricey.
Now, the only exception to having the front and rear axle ratios match is if you intentionally mismatch the axle ratios and tire diameters in order to get a "look" (or other desirable trait) and keep the TCase happy. For instance, you could run a 26" tall tire with 3.42's in the front with a 30.5" tire and 3.73's on the rear (if you liked the big / little look). Only place I've seen that done is I think Quadraduece's 2nd incarnation (but I'm not sure) and most 4wd tractors (like the FarmPro ones that Northern Tool sells).
'JustDreamin'
